Configures the maximum IPv4 ICMP allowed size.
| size | Specifies the size of the IPv4 ICMP in bytes. |
| slot | Specifies the slot to be used. |
| all | Specifies all IP addresses, or all IP addresses in a particular state. |
The default size is 512 bytes.
This command configures the IPv4 ICMP allowed size. The absolute maximum is 1023 bytes.
This command was first available in ExtremeXOS 12.0.
